I am very new to PIC programming. I have PIC12F675 and I was just wondering if I need something else than connecting MCLR to VDD for it to work. As I understand extra components are not necessary for it?
For start I just want to toggle output every second:
void main()
     TRISIO = 0;
     while(1)
             GPIO = 0;
             delay_ms(1000);
             GPIO = 1;
             delay_ms(1000);
In mikroC I use these parameters: enter image description here
For uploading hex I use K150 programmer. I read the MCU memory and it seems uploading works. Then I put it on breadboard with 10kOhm resistor (MCLR->VDD).
When I connect 5.26V to it, it uses ~130uA for ~5s and then stays stable at 40uA. I do not notice any output voltage changes on any GPIO (check with voltmeter-multimeter). What am I doing wrong?
Here are the oscillator choices: enter image description here
You have selected an RC oscillator as the clock source, but have not connected one, so the PIC has no clock and therefore will not run.
    \$\begingroup\$ Which one should I choose? INTOSC? \$\endgroup\$
    – Ri Di
    Commented May 21, 2023 at 7:22
  • \$\begingroup\$ I don't know what options you have. Selecting an internal oscillator sounds like a good idea. \$\endgroup\$
    – Justme
    Commented May 21, 2023 at 7:25
    \$\begingroup\$ So I can use internal without any extra parts, right? \$\endgroup\$
    – Ri Di
    Commented May 21, 2023 at 7:26
    \$\begingroup\$ I chose the second - it works! Tahnks. \$\endgroup\$
    – Ri Di
    Commented May 21, 2023 at 7:37
    \$\begingroup\$ You might also need to configure the pins from analog to digital I/O, using "ANSEL=0", but apparently it works without this, or perhaps you have not shown all the code. Perhaps MikroC takes care of that automatically. It does differ from MPLABX and XC8, which I use. \$\endgroup\$
    – PStechPaul
    Commented May 21, 2023 at 7:49
