I have a circuit with PIC16f628a
interfaced to Holtek HT16C21
Display RAM IC via I2C interface, I have two MCUs one is Original software from OEM and second one is containing software written by me, when I use the original controller it works fine which means the hardware is OK, but when I put my controller on hardware then the HT16C21
never acknowledges the first address byte, when I test the same code with 24c32
and PCF8574
on proteus, it works.
If the Hardware is OK, and my software is working on another ICs on proteus
, why it is not only working with HT16C21
The address of HT16C21
is 0x70
in datasheet
3\$\begingroup\$ It's time to power up an oscilloscope and acquire some traces of SDA and SCL during a transaction. Also post a schematic that details all of your connections. Also indicate the bus pull-up values in use and cable lengths. And then some folks will also want you to post your code. \$\endgroup\$– Chris KnudsenMay 22 at 12:19
1 Answer
Issue resolved. The problem was the diode that is connected on the SDA line for reverse protection (I think), which prevented the HT16C21 pulling down the SDA of the PIC16F628A while acknowledging. I bypassed the acknowledge in code, and the problem was solved.
5\$\begingroup\$ Nobody could have guessed that you have a diode on the bus. It would have been immediately seen if you had posted a schematic or said you have a diode on SDA, which would have triggerer alarms for anyone familiar with I2C. \$\endgroup\$– JustmeMay 22 at 15:58
5\$\begingroup\$ "So I bypass the acknowledge in code so problem solved," ...that is until a NAK gets asserted, and you won't be able to detect it, and the ice cream comes out chocolate instead of vanilla. ...or the green light turns on, instead of the red. \$\endgroup\$ May 22 at 16:57
\$\begingroup\$ @Justme, yes the schematic should be posted for proper resolution. \$\endgroup\$ May 23 at 15:48
