Need your help regarding SC200E USB. As per my understanding SC200E supports both USB2.0 and USB Type C.
My question is can we use it separately.
I mean we need to connect the USB2.0 signals of SC200E to another microcontroller(FS32K148UJT0VLQT) present in the other board
and we are planning to take out the type C signals to type C connector for programming the SC200E module.
Please see the below block diagram. enter image description here
I think you're confusing USB-C and USB 3 SuperSpeed. "SuperSpeed" is what these "SS" in the signal names are for!
Can't have a standards-compliant USB 3 bus without USB 2 D+ and D-, simple as that; USB bus arbitration is based on that, so it plain wouldn't work with normal hardware.
  • \$\begingroup\$ Thank you. My mistake, Yes it is usb super speed.So we can't use USB2.0 separately. I am planning to use a USB switch in the path that can be enabled for debugging and programming.May I know your thoughts. \$\endgroup\$
    – Confused
    Commented May 24, 2023 at 6:41
    \$\begingroup\$ You can't use usb3 separately. You can certainly switch between different ushers of the USB 2 lines. A hub won't help you, as they can't switch the role of pets between upstream host and downstream devices. \$\endgroup\$ Commented May 24, 2023 at 15:39
  • \$\begingroup\$ I am planning to use USB switch on USB2.0 lines.I won't be using usb super speed in my board.Decided to go with only usb2.0 \$\endgroup\$
    – Confused
    Commented May 25, 2023 at 4:05
