Let's say we have an AND gate and we give 1 as one of its inputs and we tie the other input to the gate's output. What will happen?
    \$\begingroup\$ (You misspelled its in the title.) Make a table: what happens starting with output true, what with false? \$\endgroup\$
    – greybeard
    Commented May 25, 2023 at 16:19
  • \$\begingroup\$ i can't understand how it works. i mean its kinda like that we give only one input to AND gate. \$\endgroup\$
    – Emz
    Commented May 25, 2023 at 16:21
  • \$\begingroup\$ Does that indeed look that way once the output is false? \$\endgroup\$
    – greybeard
    Commented May 25, 2023 at 16:23
  • \$\begingroup\$ My main question is that; how can the output be determined when we dont have all inputs?! \$\endgroup\$
    – Emz
    Commented May 25, 2023 at 16:26
    \$\begingroup\$ @Emz You seem to think there is no input. There is. It's just unknown. When you power up that circuit, it may either power up in state of output hight or low. As a simpler example, what happens if you have a simple inverter, and connect the output to input? (Hint: depends strongly on the type of inverter). \$\endgroup\$
    – Justme
    Commented May 25, 2023 at 16:44
7
Depends on the initial state of the output!
Output is LOW at t0
Now your input signals are LOW and X... AND requires two HIGHs....So the Output will remain LOW independent of any change on X
Output is HIGH at t0
Now your input signals are HIGH and X. If X turns out to be HIGH at t0 as well, the output will stay HIGH until X goes LOW.
But, now (Output went HIGH to LOW) it will never be able to go back to HIGH again.
Transient Case
In case of a real system beeing powered on nobody can really tell. The Output could glitch HIGH for a brief period before going LOW...Even if your X input is LOW all time.
Steady state
Assume your system is powered up and running in a steady state with the output beeing LOW and the input beeing LOW. If you change your input to HIGH nothing will happen - the output will stay LOW.
  • \$\begingroup\$ How can we talk about the output at t0 when we dont have all the inputs at t0? if we want the input we have to know the output and if we want the output, we have to know the inputs. \$\endgroup\$
    – Emz
    Commented May 25, 2023 at 17:00
  • \$\begingroup\$ @Emz, I think you maybe are asking about the "power-on transient behavior" of the AND gate. Unfortunately, that is not something that anybody ever defines for a generic AND gate. Real-world stateful circuits (your circuit is an extremely simple state machine) include some kind of reset logic to ensure that the machine powers up into a known state. IDK much about designing reset logic except that it typically is not entirely digital. \$\endgroup\$ Commented May 25, 2023 at 17:05
  • \$\begingroup\$ @SolomonSlow so when this circuit power up we cant know what will be the output? i mean is it random? \$\endgroup\$
    – Emz
    Commented May 25, 2023 at 17:12
  • 4
    \$\begingroup\$ @Emz, "Random" isn't the right word. If you actually build the circuit, you might find out that it always powers up the same way every time. If you build another copy using a supposedly identical AND gate, it might power up the opposite way every time. Or, maybe what way it powers up depends on temperature, or maybe it depends on capacitance in your power supply or, IDK what else. The right word to describe that kind of behavior is "undefined." \$\endgroup\$ Commented May 25, 2023 at 18:11
The wealth of SE EE
I have always said that the biggest asset of SE EE is not the answerers, but the questioners because what we explain can be found in sources but such original, interesting and thought-provoking questions cannot be found there.
Now, in this particular case, what a wonderful question that is! Perhaps a century ago, the inventors of latches and flip-flops asked themselves that and so invented them? If they were not, there would not be flip-flops, RAM, registers, computers, smartphones, internet, web, SE EE... and we would not be here...
Possible ways to answer
If you know what a "latch" is
It is a great idea to see the familiar old in the unknown new. Then the answer to the OP's question is extremely simple - it is just an RS latch (flip-flop if you prefer), only it is missing one input (S). But still it is a latch that fulfills its main purpose of storing data.
If you do not know what a "latch" is
... or you know but do not see the connection to this question, the best answer for you will be to build the circuit of an RS or R'S' latch (the apostrophe means inversion) step by step from the very beginning to the end, revealing at each stage the need to add a new element.
Ok, let's assume this is your case. Even if it is not, let's assume it is because the benefit is great - we are going to do something new that has not been done before. Instead of using trite "explanations" such as "this is...", we will explain exactly "why this is so".
Revealing the truth about latches
I actually did this a year ago in my answer to a related question but now I have the chance to do it by means of CircuitLab.
The most elementary memory cell...
... with hysteresis...
The greatest challenge in circuitry is to make something out of nothing; then it is an invention:-) Such an "invention" would be to make the simplest 1-input logic gate (buffer) "remember".
If the element has multiple inputs (e.g., a 2-input NAND), we can simply join them.
If we investigate the behaviour of such a CircuitLab element by driving it with a triangle-shape input voltage, we will see something interesting - it has two input thresholds (VL = 2 V and VH = 3 V).
1-buffer hysteresis_1
Ah... that means the element has the so-called "hysteresis" or, in other words, "memory". So we can make a latch (flip-flop) with it without any extra elements, just by driving it appropriately.
This means that we can set it by briefly applying +5 V and reset it with 0 V but the rest of the time we must apply 2.5 V (the middle between the two thresholds)...
1-buffer hysteresis_2
... and the element without memory already remembers.
1-buffer hysteresis_3
... with positive feedback
However, if the element has no hysteresis, we can apply another trick called "positive feedback". Thus, if we connect the output of a non-inverting amplifier or a digital buffer to its input (the OP's idea), it becomes the most basic element with memory aka "latch" or "flip-flop". Thanks to this "self-reinforcing" positive feedback, it can only be in one of its two end states - LOW and HIGH.
To understand how this "magic" happens during the transition between the two states, you need to think of this fast digital device as a slow analog device (integrator) that seeks equilibrium but never finds it and finally reaches the supply rails. So this device is an amplifier but it never works as an amplifier (in active mode); it works either as an integrator or it is saturated.
... controlled by one source
To change the state of this memory cell, we must "pull" the output of the amplifier "down" or "up" and then leave it alone (disconnected from the input source). This is a rather "brutal" action because there is a conflict between two voltage sources (the amp output and the input source), but still it is widely used in computer RAMs. We can do (assemble) such a "3-state pulse input source" in the CircuitLab simulation by connecting two oppositely acting pulse input sources R' and S (CSV) through decoupling diodes to the amp output. So they will be switched off when they are not active and the cell will remember undisturbed.
Let's see it by the help of the time-domain simulation in the graphs below.
At 5 ms, the input source S briefly (for 5 ms) "pulls up" to 5 V the amp output through the diode D2, and then returns to ground so D2 is off.
1-buffer latch_2
This forces the amplifier to go high and feed itself a 5 V at the input, thus maintaining itself in that HIGH state.
1-buffer latch_3
At 30 ms, the input source R' briefly (for 5 ms) "pulls down" to ground the amp output through D1, and then returns to +5 V so D1 is off.
1-buffer latch_1
This forces the amplifier to go low and feed itself a 0 V at the input, thus maintaining itself in that LOW state (see the graph above).
... via separate input
Here we remember that apart from 1-input there are also 2-input logic gates, and we can use a separate control input. Obeying the OP's wish, we take a 2-input AND logic gate and connect its one input to the output and apply an input pulse signal Vin to the other.
... with initial setting
But a problem appears - the cell is initially set by CircuitLab in the zero state and the AND input can change (reset) the output only in the zero state (property of the AND logic function). Then let's add another setting pulse voltage source Vset that "pulls up" the output in the beginning of the simulation.
At 5 ms, the initial setting source Vset briefly (for 5 ms) "pulls up" to 5 V the amp output through the diode D, and then returns to ground.
1-AND latch_1
This forces the amplifier to go high and feed itself a 5 V at the input, thus maintaining itself in HIGH state.
1-AND latch_3
At 30 ms, the input source Vin sets the output to zero and after that it loses its control properties.
1-AND latch_2
Cascading ANDs
A new "powerful" idea comes to us - to introduce a second input signal Vin2 by including another logic gate AND2 after the first one... and this way we take a decisive step towards the "invention" of the famous RS latch.
But that does not change things because both inputs act the same way (in the same direction) and everywhere along the positive feedback circuit the voltage is 0 V; the circuit is locked.
2-NAND latch_2
2-NAND latch_1
2-AND latch_3
2-AND latch_4
Cascading NANDs
We are already aware of the problem - the states of the inputs and outputs must alternate, and this means using NAND logic gates.
At 10 ms, the input Vin2 toggles the latch (Vout1 = 0 V, Vout2 = +5 V) and loses its control properties. Next time we have to use Vin1 to toggle the latch.
2-NAND latch_2
2-NAND latch_4
At 30 ms, the input Vin1 toggles the latch (Vout1 = +5 V, Vout2 = 0 V) and loses its control properties. Next time we have to use Vin2 to toggle the latch.
2-NAND latch_1
2-NAND latch_3
Conventional schematic
Thus we get the ubiquitous RS (R'S') latch. Before we show our "invention" to others, let's draw the circuit in the conventional "cross-coupled" way. But we know that it is cross-coupled just because it is drawn in such a way.
The results of the time-domain simulation are the same as above.
Conclusions
  • The simplest possible latch can be made with only one logic gate (without any external elements) if it has input hysteresis. It has to be controlled by an input signal with three levels - 0 V, 2.5 V and 5 V.
  • Another simple latch can be made with only one (AND or OR) logic gate by connecting one of its inputs to its output (the OP's idea) but it also cannot be controlled with conventional (referenced to ground) input signals.
  • It can be controlled by only one input signal with three states - two active (low and high) and one passive (disconnected aka "high impedance").
  • To control the latch by two referenced to ground input signals, we have to connect (cascade) another logic gate.
  • The two cascaded logic gates cannot be non-inverting (AND or OR); they must be inverting (NAND or NOR).
  • This so-called R'S' latch is controlled by two input signals with three states - two active (R' = low, S' = high; R' = high, S' = low) and one passive (R' = high, S' = high).
The result is influenced by the analog nature of the otherwise binary device.
The output is one of the inputs. So there will always be two inputs. During the day power-on transient the gate will act as an amplifier with positive feedback. There will be either oscillation or latching in one direction. It may be predicted with good knowledge of the internal circuit.
If (after power-up) one input is high and the other stable, switching the other input to the output will likely retain the same state, then positive feedback will latch the state.
