Design a Schmitt trigger using a IC 393 comparator (open-collector output) with thresholds at +1.0 volt and +1.5 volts. Use a 1.0 k pullup resistor to +5 volts, and assume that the 393 is powered from 15 volt supplies.
6\$\begingroup\$ I’m voting to close this question because it appears to be homework with no attempted solution. \$\endgroup\$– JREMay 26 at 13:04
5\$\begingroup\$ Please ask the actual question in the title! "can someone help me with this?" is a generic question that applies to every question in stack exchange. \$\endgroup\$– Davide AndreaMay 26 at 13:14
