I am trying to build a step-up and step-down circuit from a DC-DC converter IC.
This is from the datasheet:
I have two questions in relation to this:
- The value of the resistor in the red box. It says 0.22. Is this in ohms? 0.22 ohms seems quite peculiar to me.
- Regarding the
Vout
calculation. You can look at the red line in the bottom of the screenshot. It looks likeVout
is calculated by selecting values only for theR1
andR2
resistors. Is this correct? Shouldn'tVin
be taken into consideration as well?
