I am trying to output a 2 bit-number that indicates which input signal changed during the time span when "detection mode" is switched on by another input signal. The output is saved in a register.
Each time detection mode is switched off and on again, the output/register should be set to 0.
So the register depends on changes in multiple signals. The way I know of to react to signal changes is using always blocks. However, inside one always @* block reacting to any change, as I understood, it is not possible to differentiate between changes in different signals and react to each of them in a separate block, as always cannot be nested, and @negedge / @posedge is not synthesizable.
I do not use a clock, purely combinatorial logic, to limit complexity in the overall FPGA-Microcontroller system. Unless there is no other solution, this should not change.
Edit on May 28, 2023 The signals are independent from each other and use a one-wire data transmission protocol without a second clock line. The minimum period between signal changes is around 100ns. I prefer not to have to include a clock detection circuit. Only one input is connected at a time. The aim of the circuit is to detect which input is connected. Edit end
I have difficulties realizing this behaviour using only one always
block (always @*
). Using several always
blocks, I run into the problem that one register cannot be set by several always
blocks.
I could not find any hints on how implement this logic on stackexchange or elsewhere. I believe that maybe combinatorial logic with more registers could somehow lead to the desired result, but I am not sure how.
Neither do I understand how I can integrate the always @Local_Mother1
and 2 blocks into the first always
block and set the Signal Number inside that block correctly.
My code looks as follows, but results in an error (Only one always
block can assign a given variable)
input wire Local_Mother1, Local_Mother2; //The signals to be detected (only one signal may be connected)
input wire Steuerung; //Used for controlling detection mode
reg r_LMCode[0:1]=0 ; //Initialized at 0, this synthesizes using Lattice ICE40 - Signal number
reg r_LMdetectmode=0; //Initialized at 0, this synthesizes using Lattice ICE40 - Detection mode
//Handle the detection mode switch-on and off
always @(Steuerung) begin
if (r_LMdetectmode==0) begin //detection mode off
if (Steuerung==1) //This switches on detection mode
r_LMdetectmode <= 1;
//r_LMCode <=0; //could be set here as well, but does not change the problem
end else begin //Detection mode is on
if (Steuerung==0) begin
r_LMdetectmode <=0; //Switch off detection mode
r_LMCode <= 0; //Signal Number set to 0 - gives an error!
end
end
end
always @(Local_Mother1) begin //in case Signal 1 has changed
if (r_LMdetectmode==1)
r_LMCode <= 1; //Set signal number to 1 if detect mode is on - error!
end
always @(Local_Mother2) begin //in case Signal 2 has changed
r_LMCode <= 2; //Set signal number to 2 if detect mode is on - error!
end
