To check high frequency signals on an oscilloscope you should use the X10 probe with ground spring for lowest inductance on the ground connection. Using the alligator clip lead will often result in ringing, out-of-shape signals, or common mode to differential conversion. The wire loops can also catch stray fields from the inductor/PCB. So the scope can display noise that isn't actually there. At 1µs/div on the scope it should not be too bad, but if you go faster it matters.
Without a load at the output, these buck chips can enter a low power mode and cycle between sleeping then bursts of switching. In this case, output ripple voltage is slightly higher, it depends mostly on the hysteresis of the internal comparator that controls sleep mode entry/exit. When there is enough load on the output to push the chip out of power-saving mode, it will switch continuously and ripple voltage will be lower. So make sure you know which mode the chip is using. You can use a load resistor on the output to draw say 50mA to force it to run in continuous mode.
The input current of a buck converter looks like a square wave with sloped tops as shown on the second plot in this image (source):
This input current has very high di/dt as the internal MOSFET in the buck chip switches, which means:
The output cap handles the inductor current which is a sawtooth, so it is less critical. If the output cap is weak you will get more ripple. But the input cap really is important, if it is badly chosen it won't work at all. Here's why:
A typical 10µF MLCC has an ESL of ~1nH, say 2nH with some short traces, and very low ESR around a few milliohms.
The caps you used, if they're general purpose aluminium, should have ESL around 2-4nH and ESR of a few ohms to a few tens of ohms.
Usually for general purpose caps, ESR is specified using dissipation factor at 120Hz and 25°C. So your 10µF cap would have 13-26 ohms ESR at 120 Hz, 25°C. Actual ESR depends on frequency and temperature, here's an example:
So, ESR at your switching frequency will be lower than the value calculated from datasheet dissipation factor, especially if the capacitor is hot. Looking at the ripple on the scope plot (about 1V) and the inductor ripple current calculated from inductor value and input/output voltages (400mA) it seems the cap has an effective ESR around 2-2.5 ohms. It's better than 13 ohms, but it doesn't matter: it's still 100 times too high.
The shape of the scope trace provides a hint: it's a sawtooth, just like inductor current. If the voltage has the same waveform as the current, it means the cap doesn't act like a cap, it acts like a resistor! ESR is so high that the cap doesn't smooth the voltage at all. With a low ESR capacitor, the cap would actually smooth the output voltage, and it would no longer look like a sawtooth: a capacitor integrates current into voltage, and turns a sawtooth current into a piecewise quadratic voltage. On the scope this looks more like a sine, with "rounded" tops and bottoms.
So, on the ESR alone, it's not going to work at all. ESR is way too high, and when the internal MOSFET turns on, input voltage is going to drop significantly. In the worst case I've seen, input voltage dropped enough to trigger the undervoltage detection of the chip, so it would reset, wake up, think it's just been powered up, and run the whole soft-start again. This resulted in a sawtooth output voltage.
You should probe the input voltage right at the chip (using the tiny ground spring on the probe) to assess this. If I'm correct about the problem being the ESR, you should see a lot of ripple voltage.
The footprint pads on your PCB should be close enough to remove the electrolytic caps and solder some 1206 MLCCs or maybe 0805 instead. Use the recommended values from the datasheet, or higher.
It won't fix the layout, which is not optimal, but it should work a lot better with ceramics. If you don't have 2.2µF you can stick 2x 1µF on top of each other or side by side, or use a larger value. Doesn't matter if it's ugly, this is mainly to check if it works better. MLCC size doesn't matter since most of the inductance will be in the traces. Just use whatever you have as long as it has enough µF and it fits.
Note that ESR of a electrolytic capacitor increases a lot when it's cold (shown on above graph), this is due to the liquid electrolyte losing its performance when cold. Ceramics are fully solid so they do not have this drawback, although capacitance varies with temperature ; X7R/X5R perform well in a wide temperature range but cheaper Z5U/Y5V variants, not so much.
Since you're powering this with wires which do have inductance, I strongly recommend adding an electrolytic cap at the input for damping, whatever value comes out of the parts bin will be fine as long as it's 100µF or more.
Once you do that the buck converter should work. High frequency noise due to sub-optimal layout should be mostly spikes at switching, which you may or may not see on your scope depending on how much bandwidth it has. This chip probably switches in a few tens of nanoseconds or less, which will create noise spikes of similar duration... so if the scope and the probes don't have several hundreds MHz bandwidth and the necessary rise time, you can't trust what you see on the screen.
Note the datasheet paragraph "8.3.3 Enable" says the chip has an accurate voltage threshold on the enable pin. So you can use a voltage divider from Vin to make sure the chip starts at, for example Vin>6V, to ensure the output is either clean 5V or 0V. Otherwise, by tying Vin to EN, if Vin is lower than 5V it will still start but it will not be able to output 5V.
