I want to monitor the waveform of a high voltage (8kV) 3Hz to 1000Hz DC pulse form. It has been suggested that I use 1pf capacitor in series with a 1000pf capacitor, then put the scope across the 1000pf capacitor for a 1000 to 1 voltage divider.
I have a few questions:
- Will a 3 Hz DC pulse with a 50% duty cycle, look true, (i.e. flat tops without droop) with a capacitive divider?
- How will the 10X scope probe load such a circuit and alter the waveform and amplitude?I will alter values as needed.
- Would I be better off using a resistive divider?
I want to keep the current low, under 0.5 uA.
