I'm trying to build a li ion low charge current detector and cutoff circuit as a complement to my battery charging setup. Charging should be disconnected when the current reaches 400mA or below. I've started with the simplest circuit I could muster, and true to form - it doesn't work as expected.
Apologies, I realize I didn't draw in the INA180 and LM393 supply configuration. Both devices are powered by the 5V rail and decoupled by 100nF.
The circuit is pretty straightforward: high-side current sensing using the INA180 drives a comparator with a reference voltage of ~0.8V. When the comparator goes high, it switches on the SCR, which drives an LED in the schematic above, but will eventually drive a relay that cuts the 17V rail.
The SCR will latch so that the 17V rail is kept open until the power to the circuit is removed (the laptop power supply is turned off).
At this stage, I'd prefer to have everything powered from the laptop supply and I am aware of the issue of sharing grounds on either side of the dc-dc converter. I believe if I try to connect the laptop ground and converter ground together (which would be convenient) I would interfere with the converters ability to regulate the current, but I haven't experienced any issues with the setup above and that's not my main problem.
The problem I'm having is that when the laptop supply is turned on, and even with > 400mA expected to flow across Rsense, the SCR is triggered on (i.e., the charging is switched off). I believe the issue is that the reference is established before the current is sensed across Rsense, which will always drive the SCR on. A solution might be to delay the SCR triggering action until the comparator voltages are properly established. Any ideas?
INA180 Dataheet
SCR Datasheet
    \$\begingroup\$ Between which points is the battery connected? The circuit looks like a short between +17 and GND via the shunt resistor. A capacitor between Vref and GND can delay the comparator action after power on. \$\endgroup\$
    – Jens
    Commented Jun 5, 2023 at 20:18
  • \$\begingroup\$ @Jens Thanks Jens. My bad, the battery would be the load, between Rsense and ground. The circuit reflects the prototype, which is not quite the final iteration. Of course, the converter is CC/CV and the current is limited, so no fireworks;) \$\endgroup\$
    – Buck8pe
    Commented Jun 5, 2023 at 20:27
  • \$\begingroup\$ I think I'll try a slightly different approach. An AND gate after the comparator, with an RC delay off the 20V rail. The Schmidt trigger action is an added bonus, although at this stage I'm thinking just use a small uP and be done with it. Just being stubborn. \$\endgroup\$
    – Buck8pe
    Commented Jun 5, 2023 at 20:32
