What is the pink axial component in this picture? The datasheet for the proximal IC suggests it probably is a resistor, but I'm having trouble figuring out it's resistance value given that it doesn't seem to match 5-color band coding.
mystery component
It appears to be a 0.47Ω 5% resistor. The black band may indicate non-inductive.
  • \$\begingroup\$ Wow, that is VERY helpful. Thank you! \$\endgroup\$ Jun 6, 2023 at 3:18
