I would like to know if there are already ASICs/FPGAs implemented on top triple modular redundancy for fault tolerance/if they themselves implement TMR for fault correction. Any reference to research paper describing such implementation would be appreciated
ASICs are custom, so you can do what you want. Some FPGAs and CPLDS have built in "rad-hard" (RADiation-HARDened) versions that resist the errors rather than have fault tolerance.
But most FPGAs don't have that feature. On the last space FPGAs I worked on had 3 big FPGAs (Xilinx) for redundancy. A small rad-hard Actel FPGA to perform the TMR comparison.
Xilinx does have a tool for adding TMR within certain FPGAs.
