I'm designing a single channel 4-20 mA current loop transmitter using XTR111 IC. By following the reference design guide from TI.
link: https://www.ti.com/lit/pdf/tidub12
Circuit schematic reference: https://www.ti.com/lit/pdf/tidrwl8
In the schematic, why the REF5050AIDGKT voltage reference IC is used? What is the purpose of it?
Power source: 24 V local power supply
Can't I give a 3.3 V supply from my external LDO to DAC VDD that is derived from the same 24 V supply and voltage to DAC Vref pin from the Vreg pin of XTR111?
