It is used in Automotive vehicle on Power Electronics Module. I don't know which manufacturer it belongs to.
https://i.sstatic.net/DJxPk.png
    \$\begingroup\$ Welcome! The image is broken. \$\endgroup\$
    – winny
    Jun 9, 2023 at 13:14
    \$\begingroup\$ Ganesh Thiva - Hi, As commented, your image link doesn't seem useful (it seems to be a yellow square). For identification questions, please follow these guidelines. At the moment, your question does not include the required information as explained at that link. Please edit your question and add that information. Also, since you are new here, please see the main site rules in the tour & help center, as the rules here differ from typical forums. Thanks. \$\endgroup\$
    – SamGibson
    Jun 9, 2023 at 13:17
The "721P" marking and claimed package matches with a RUNIC Tech RS721PXF Op Amp.
If you provide a picture of the surrounding components, I can check if the pin out and device type is plausible, otherwise you have to check for yourself.
  • \$\begingroup\$ Thanks for the support bro, it matches... how did you found it brother!! can you give me some ideas \$\endgroup\$
    – Resist Cap
    Jun 10, 2023 at 18:02
    \$\begingroup\$ @GaneshThiva Your welcome. If this is the correct part, please accept the answer by clicking the check mark. I found it by simply google searching 'SOT-23-5 "721P" markings'. Sometimes it's that easy ;) (usually not though). \$\endgroup\$
    – nanash1
    Jun 11, 2023 at 9:05
  • \$\begingroup\$ sure bro..thanks a lot... can i get your linkedin user name!! so that i can follow u \$\endgroup\$
    – Resist Cap
    Jun 11, 2023 at 13:04
