I want to make a PCB for DC-DC converter. I used TI’s Webench tool to create a buck converter design using the TPS5604 IC.
The input voltage is 13.5V and output voltage is 6V and maximum current is 600mA. The problem is according to the Webench simulation the input current reaches 10A at the start of each switch cycle. I understand that at the start the input current will reach higher currents (around 5A). But why does it rise to such high currents in steady-state?
