How to power pressure sensor MPX2050 correctly with input voltage?
I want to use the pressure sensor MPX2050 (data sheet: https://docs.rs-online.com/65ac/0900766b814a74eb.pdf)
These are some values from the data sheet:
Supply Voltage: typ 10 V, max 16 V
Supply Current = 6 mA
Input Impedance: min 1000 Ω , max 2500 Ω
Output Impedance: min 1400 Ω , max 3000 Ω
I have a few questions about how to feed this sensor correctly with input voltage:
Can I directly connect a battery (9V) (or a battery pack 12V) to the pressure sensor MPX2050 (Pin 1 GND, Pin 3: Vs)?
Does "supply current = 6 mA" mean that it is kept constant by the pressure sensor circuit, or is it necessary to limit the correct by an external resistor? (e.g. 2k Ω if Vs = 12 V) 2b) Can I damage the battery if I do not limit the current with an external (of the pressure sensor) resistor?
As the level of the output voltage depends on the applied pressure and the input voltage, should I then keep the input voltage constant? I.e. should I use a voltage regulator? (e.g. LM217L or LM317L)
