Say I have a large soft surface such as a jacket and I want to register it getting hit by a paintball from a paintball gun, how would I do that? What type of sensors could I use?
a piezoelectric sensor will create an electrical signal when hit. They are used in many different types of devices and would most certainly register a paintable hitting a jacket.
| improve this answer | |
  • \$\begingroup\$ I recall Giotto en.wikipedia.org/wiki/Giotto_mission had three on its dust shield to triangulate impacts and these being plotted in real time on the TV, though obviously that's a much faster projectile hitting a hard surface. \$\endgroup\$ – Pete Kirkham Nov 14 '10 at 0:02
Not going to be easy, i don't think an accelerometer is going to cut it.
I think the easiest answer would be to modify the jacket (or make an under shirt) which is pressure sensitive.
You could do this by using 2 layers of conductive fabric and a sparse semi insulator in between and carefully sewing it all together. Setup a circuit to measure the resistance between the 2 conductive fabric layers and when something compresses them (such as a paintball) the resistance should drop.
Alternatively, if a paintball is really your use case, you could use a microcontroller with a little microphone somewhere on the jacket and process the audio looking for the sound of the impact. More math work, less sewing.
  • \$\begingroup\$ Conductive fabric is the way to go. If you're using this in a paintball match, it means the person wearing it will likely have a paintball gun, which will drown out the impact sounds in the microphone option. \$\endgroup\$ – Connor Wolf Nov 14 '10 at 7:02
How about piezo film sheet eg http://www.meas-spec.com/product/t_product.aspx?id=2488 ?
