I have a 250W dc brushed motor running off 24v. I controlled it with hbridge controllers rated for 40A, which should be enough... I thought. My reasoning being that 250W at 24v would limit it to 250W/24V=10.6A
This worked well enough, but when I prevented the motor from turning, the controllers blew. I then changed to building my own hbridge with 4 solid state relays rated at 80A, and when testing stalling the motor they died as well.
I measured about 1-2 Ohm resistance through the motor, when not connected, and with it being rated for 250W at 24v, that seemed reasonable enough, and should confirm the approximate maximal 10A current.
Obviously I am missing something here. Am I making too simplistic assumptions about the motor? I do not have any diodes connected to prevent back current, when motor is off, but spinning, and I did end all tests with letting it spin up to speed, so it could perhaps be the issue, but I was not expecting that to be greater than the stall current anyway.
My first large motor project, though, so I apparently need to understand something more...
