Please help me identify what this male connector is. Pictures are attached (both of the male plug and female socket it plugs into). It is from a 40mm fan that plugs into a socket of a PSU of a Surveillance Network Video Recorder.
The 2 pins have a spacing of 2.0mm.
The width of the male plug is 4mm.
I thought it might be a HY2.0mm 2-Pin Connector (looks very similar), but the male plug for this is 5mm in width and hence doesn't fit into the female socket.
Appreciate any assistance you can provide.
Looks like JST PA series.
Male plug photo: enter image description here
Female header: enter image description here
Datasheet: https://www.jst.co.uk/downloads/series/ePA-F_(21-03-26).pdf
  • \$\begingroup\$ It certainly does - thank you. Will get hold of one of those and see if it fits. \$\endgroup\$
    – John
    Jun 15, 2023 at 0:48
