I bought used Sinano Kenshi STP-43D1034 steppers with a connector attached the coils. Spent a few hours and wasn't able to identify the connector type. At this stage I would like to avoid changing the connector. It does not seem to be a JST or a Molex connector. Contact's pitch is 2mm or very close to that. Any suggestions what kind of connector that could be, would be very appreciated.
Top view of the connector Side view of the connector Front view of the connector
  • \$\begingroup\$ Post pictures of its mate, please. \$\endgroup\$ Jun 14, 2023 at 11:38
I identified it with my Identiconn utility.
It's a TE, CT.
https://connectorbook.com/identification.html?m=NN&n=lo_prof_1r_w2b_conn_2&s=CT%20(crimp%204w%201r)
2mm AMP CT Connectors
Housing: https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/179228-4/1855274
TE CT housing
{Digikey}
    \$\begingroup\$ That's exacly it. Thank you! \$\endgroup\$
    – wedark
    Jun 14, 2023 at 20:35
