Good afternoon. I use 18650 to power the radio machine. An XL6009 is connected to the output of the TP 4056 board to receive 5V, and then these 5V are fed to the machine board. But you press start on the remote control, the TP 4056 board goes into protection and does not provide power from 18650
Both boards work individually correctly. If you connect the power of the machine without XL6009, then everything also works correctly. But need 5-6V
I couldn’t find all datasheets for the boards, but a good description of them is here:
