I need to use two line drivers for the communication between two PCBs. I am currently using MAX3081 from Analog and this is what I see in the datasheet:
pin configuration and typical full-duplex operating circuit
Image Source: Analog - MAX3080-MAX3089 datasheet
Now my doubt is about the pins Y, Z, A, B. They are:¨
  • Y: Non inverting driver output
  • Z: Inverting driver output
  • A: Non inverting receiver input
  • B: Inverting receiver input
For proper connection between the two integrated circuit (IC1 and IC2), should I cross them and connect as following?
  • Y(IC1) -> A(IC2)
  • Z(IC1) -> B(IC2)
  • A(IC1) -> Y(IC2)
  • B(IC1) -> Z(IC2)
Or did I get it wrong? Thank you!
You should connect them as shown in the image. Your connections are correct.
(Cross between the driver and receiver, but do not cross the non-inverting and inverting signals.)
