I'm working on adding extra access control to elevator calling buttons and i would like to identify the connector type of the wires connecting elevator buttons to the elevator panel
I have tried Micro JST 1.25MM 3-Pin Male & Female Connector Plug, it has the same Pitch Mating size of 1.25mm but unfortunately the connector itself is smaller than the original one.
original connector against Micro JST 1.25MM 3-Pin
Mitsubishi elevator calling button original connector
Mitsubishi elevator calling button with Micro JST 1.25MM 3-Pin
    \$\begingroup\$ Does this answer your question? Is there a guide how to identify connectors? \$\endgroup\$ Commented Jun 15, 2023 at 9:33
    \$\begingroup\$ You threw me off and sent me down the wrong path for 10 minutes with your incorrect dimensions. The pitch of the original connector is 1.5 mm, not 1.25 mm. \$\endgroup\$ Commented Jun 15, 2023 at 12:00
I found it with my Identiconn utility.
It's a JST ZH: 1.5 mm pitch.
https://connectorbook.com/identification.html?m=NN&n=lo_prof_1r_w2b_conn_1p5&s=ZH
JST ZH
{Digikey}
    \$\begingroup\$ Visual inspection confirms your answer, thanks a lot for your help and sorry for incorrect dimensions. \$\endgroup\$
    – elmasrydev
    Commented Jun 17, 2023 at 10:25
