I want to use this tactile switch in my PCB design: https://datasheet.lcsc.com/lcsc/2002271735_XKB-Connectivity-TS-1101-C-W_C318938.pdf
As you can see in the document, the distance between the edges of the pins is 8mm. I searched for all the available footprints in KiCad's library, but I did not find a single one with these dimensions.
This looks remarkable to me, as this tactile switch is a common one. Am I missing something?
