I'm using the Falstad circuits simulator. For some reason, I get a steady 6V input on V- part of the first op amp in a negative feedback connection. When I put another resistor between the voltage source and the op amp, the V- suddenly goes to around zero as it should be.
I don't understand why in the first picture instead of 0 volts at V- I get the whole 6 volts. Perhaps I missed something.
I don't get the zero voltage at V- when the voltage of the input is near the saturation voltage of the op amp.
