I am working on a 4x4x4 LED cube. I have connected all the negative terminals of LEDs in a horizontal layer to each other, and am using one Arduino pin per layer. I have connected all the LED positive terminals of a vertical column together and am controlling each column via a pin.
So, 16 pins used for columns and 4 pins used for horizontal layers. The pins are directly powering and sinking the LEDs.
From my calculations, I can turn on atmost 16 LEDs at one time before reaching current limits. So, if I want to light up all the layers simultaneously, without burning the board, how should I go about it ?
