I have an NTC thermistor that reduces its resistance when temperature increases, but I need a circuit where resistance increases. Without using a different thermistor (or a microcontroller), is there any way that I can reverse the behavior of the thermistor so that resistance increases with temperature? Is there a component that can do this?
  • 5
    \$\begingroup\$ how is it connected in a circuit? \$\endgroup\$
    – jsotola
    Jun 27, 2023 at 17:28
    \$\begingroup\$ I haven't built the circuit yet I'm trying to see if this is even a possibility, but it will be going to an LED \$\endgroup\$ Jun 27, 2023 at 17:29
  • 5
    \$\begingroup\$ think about what happens if the thermistor is one leg of a voltage divider ... think about how the output voltage varies with temperature if the thermistor is at top, and if it's at bottom \$\endgroup\$
    – jsotola
    Jun 27, 2023 at 17:34
  • 7
    \$\begingroup\$ this is an XY question ... you ask about what you think is a solution to an unspecified problem, instead of asking about the problem you are trying to solve \$\endgroup\$
    – jsotola
    Jun 27, 2023 at 17:37
  • \$\begingroup\$ If the range of temperature is not too great, you could try a PTC thermistor, usually used as a solid state self-resetting fuse. This might help: tdk-electronics.tdk.com/download/531356/… \$\endgroup\$
    – PStechPaul
    Jun 27, 2023 at 20:47
... is there any way that I can reverse the behavior of the thermistor ...
You can't.
But you can "reverse" the behavior of the "circuit" you can use, as this :
