I had a problem with some code where I had to convert analog to digital using my PIC24HJ128GP506A microcontroller. As you may know, the microcontroller uses Successive Approximation for conversion, but I often got incorrect results.
After I implemented a small delay code, it solved my problem. However, I would like to understand: Why did the delay resolve the issue?
Code without Delay:
float readADC(unsigned int pin)
    _CH0SA = pin;
    unsigned long tmpvalue = 0;
    float result = 0;
    for(int i=0;i<50;i++){
        AD1CON1bits.SAMP = 1;
        while (!AD1CON1bits.DONE); // Wait samp
        AD1CON1bits.SAMP = 0;
        tmpvalue = tmpvalue + ADC1BUF0;
    result = tmpvalue / 50;
    return result ;
With delay :
    _CH0SA = pin;
    float result = 0;
        for(long i = 4500;i>0;i--);      // My delay
    return result ;
void configADC(void){
    // AD1CON1
    _ADON = 0;
    _AD12B = 1;
    _FORM = 0;
    _SSRC = 7;
    _ASAM = 1;
    _ADON = 1;
    // AD1CON2
    _VCFG = 0;
    _SMPI = 0;
    //AD1CON3
    _ADRC = 1;
    _SAMC = 4;
    //AD1CHS0
    _CH0NA = 0;
    //_CH0SA = 0;
    //INTERRUPT
    _NSTDIS = 1;
    _AD1IF  = 0;
    _AD1IE  = 0;
    _AD1IP  = 2;
    \$\begingroup\$ btw this:result = tmpvalue / 50;is an pure integer conversion. You need a cast to float \$\endgroup\$
    – Mike
    Commented Jun 29, 2023 at 6:10
    \$\begingroup\$ Have you switched ADCON1to auto conversion? Show your ADC init. \$\endgroup\$
    – Mike
    Commented Jun 29, 2023 at 6:12
The issue is probably the set-up time for the ADC. From the data sheet: enter image description here
It is possible that you could have a significant number of "indeterminate" readings during the 20 microseconds required to stabilize the ADC module. I would try adding a delay before your first reading, and then try reducing the time between reads and see if that helps.
