When executing the following code on my Arduino Micro, only the first line is printed:
void crash(void) {
    abort();
void setup(void) {
    Serial.begin(9600);
    while(!Serial.available()) {
        Serial.println("Please input something to begin");
        delay(500);
    Serial.println("First"); // Gets printed
    delay(500); // Make sure Arduino is done writing to the serial connection
    Serial.println("Second"); // Doesn't get printed
    crash(); // Makes the Arduino device crash
void loop(void) {
I would like to something like this to make the second line get printed, before the device crashes:
void setup(void) {
    Serial.begin(9600);
        delay(500);
    wait_for_serial_write(); // Not really a function
void loop(void) {
Which function can I use instead of wait_for_serial_write?
The reason I want to do this is because my Arduino crashes "randomly" so I have put some debug Serial.println statements, that I would like to see before the device crashes.
I also cannot use delay in my real code as the crash occurs while in a timer interrupt, where delay doesn't work.
  • \$\begingroup\$ I'm curious, what does crash do exactly? \$\endgroup\$
    – Kevin Mark
    Apr 18, 2013 at 19:20
  • \$\begingroup\$ @KevinMark Calls abort function which "Aborts the current process, producing an abnormal program termination." I don't know how it is implemented, but no code is run either in the timer or in the loop function. The Arduino doesn't reset either. \$\endgroup\$
    – Tyilo
    Apr 18, 2013 at 19:23
Serial.flush() is exactly what you're looking for.
