7
Is there a way of telling if sei()/interrupts() or cli()/noInterrupts() was last called?
I need this to be able to enable interrupts, execute some code and set interrupts disable interrupts if they where disabled.
Here is some sample code:
void function_requiring_interrupts(void) {
    bool interruptsEnabled = getInterrupsState(); // what function / variable here?
    interrupts();
    // Code requiring interrups are enabled
    if(!interruptsEnabled) {
        noInterrupts();
One way of doing this is to save, and then later restore the SREG status register, thus saving and later restoring the interrupt status to whatever it was, thus:
  uint8_t oldSREG = SREG; // Save the status
  cli();
  // Do stuff, as little as possible.
  SREG = oldSREG;
Also, the rationale described in the question has inherent problems: If some other code already had interrupts disabled, and your code enables interrupts, data corruption or program failure could occur. Any "interrupt-disabled" block of code would be expecting all registers and memory / variables to remain untainted, while enabling interrupts can cause that to change.
Therefore the reverse logic, as in the code fragment above, is best practice: Explicitly disable interrupts for your own code as needed, but restore interrupts as soon as possible, then proceed with the rest of your processing.
  • \$\begingroup\$ Anindo is right about the warning. You should never enable interrupts in a library or other call that is not specifically designed to do that. Code that has interrupts disabled did so for a reason and enabling interrupts in your library routine could cause all sorts of havoc with the other code. \$\endgroup\$ – james Apr 19 '13 at 16:46
  • \$\begingroup\$ Would it matter if an interrupt were to occur after saving the status register, but before disabling interrupts? \$\endgroup\$ – Shepmaster May 14 '16 at 23:28
