Ideal parallel LC tank has infinite impedance at resonance frequency. However, real components, especially inductors, have unignorable ESR, causing ideally infinite impedance dropping to a finite value. This also cause the LC tank resonant frequency to be lower.
Below is my calculation.
\$\omega_0\$ is resonant angular frequency. \$Z_{in0}\$ is impedance(resistance) when resonance.
According to my calculation, the resonant angular frequency is
$$ \omega_0 = \sqrt{ \frac{L-(R^2)\ C}{(L^2)\ C} } $$
The resonant impedance is
$$ Z_{in0} = \frac{L}{RC} $$
According to my simulation, the result seems correct.
I use 1 V AC signal. The "I(V1)" is current provide by the voltage source. There is 180° phase shift because the current is measured from voltage source positive to negative (from LC tank to voltage source).
$$ \mathrm{R = 40 \Omega , \ L = 10 \ mH , \ C = 100 \ nF. \\ \omega_0 = 31.369\ krad/s \Rightarrow f_0 = 4.992 kHz\\ R0 = 2.5 \ k\Omega } $$
I use these values because I have these components. Maybe I will do the experiment in real circuit.
My question is, how to find out the Q factor, bandwidth, and half-power frequency of the circuit? I have tried to calculate by myself, but it ended up I have no idea what to do next. Is it possible to find half-power angular frequency from the crazy equetion? Or I have made some mistake in some steps?
