What causes a surge suppressor to fail and burn seriously?
I faced two accidents, seemingly similar, in my power distribution system within a period not exceeding 3 months: I had what seemed to be over or surge voltage that destroyed completely the surge suppressor of 100 KA (from General Electric) and passed it to the loads network destroying all electronic ballasts of florescent tubes and some other things.
What happened and what can I do to prevent it from happening again?
  • \$\begingroup\$ Nearby lighting strike? \$\endgroup\$ Apr 26, 2013 at 20:32
  • \$\begingroup\$ Do you have a type number / datasheet? I'm sincerely curious what a 100kA surge arrestor looks like and what its specs are. \$\endgroup\$
    – jippie
    Apr 26, 2013 at 20:52
  • \$\begingroup\$ Why wasn't there an upstream fuse or breaker? If sized right, this will only blow in a large event. \$\endgroup\$ Jun 26, 2013 at 11:31
You don't actually give details - and how these surge protectors are designed is very important.
Here is what I assume you have: (if you don't have these units then the following may not be of any use)
with the most important aspect being this:
MOV's as surge suppressors are known to accumulate damage. In fact that is how they work, they absorb the damaging pulses and over time their capacity to protect is diminished.
It is hard to know what exactly happened but what is likely is that your units over time became marginal and then there was some precipitating event that overwhelmed the diminished capacity that they could no longer protect against and so the damaging waveform just carried onto the next thing to fail.
It is telling that you had two units fail close together. While not definitive it is indicative that perhaps you are in an area that has a lot of lightening or nasty stuff on the power-lines. It means you need to replace these units before they lose their protective ability.
  • \$\begingroup\$ Another way to view it: If you have MOV based protection, it needs a regular schedule of maintenance/replacement. (Even plain power strips with surge suppression will need this!) There are more expensive kinds of suppression that do not wear out like this, such as gas discharge tubes or TSPDs. \$\endgroup\$
    – Jon Watte
    Aug 25, 2013 at 16:47
  • \$\begingroup\$ Also, there are surge filters that will reduce the over-voltage, and can often go before the MOVs to significantly extend their lifetime. These may also help control EMI, depending on the circuit. \$\endgroup\$
    – Jon Watte
    Aug 25, 2013 at 16:54
