I have a cooler rated at 12V, 160mA, and a set of two 9V alkaline batteries rated at 100mA.
Would connecting it to the 2 batteries in parallel present any risks?
It's been a while since my studies so... correct me if any off the following assumptions is wrong:
- The fact that the batteries are only 9V should only impact the resulting speed of the cooler, no other damage anywhere.
- Connecting the cooler to a single battery will most likely make it overheat / burst into flames.
- Connecting the cooler to the 2 batteries added in parallel should make it spin slower, but it is safe (no damage on any components).
- Adding 2 1.5V batteries in series to each of the 9V batteries, then adding the resulting circuit in parallel and connecting the cooler should be both safe and allow the fan to get to max speed.
