I am trying to calibrate four 50kg Weight Sensors with Arduino's HX711 Amplifier AD Module. I am getting a variable range of errors. I am using this video as a reference link below. It shows me use a formula such as
Current Value= 0.8* Current value + 0.2* Sensor reading // which is taking an average of the senor
final value = ((Current Value-Actual Sensor Value) divided by reading of known weight multiplied by the known weight value
such as below,
known weight=100g
reading of known weight=2155
val = 0.8 * val + 0.2 *scale.read();
val_g=((val-159958)/2155.f*100);
The problem I am having is if I put the weight of 100 to the test the value, it keeps on changing up and down of the actual weight such as 103...101....100...102..100...97...99...103...102
I did try many attempts of calibrating but it always has that fluctuation in weight
My code:
//Oled Display
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "HX711.h"
#define WIRE Wire
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32, &WIRE);
//Weight
const int LOADCELL_DOUT_PIN = 3;
const int LOADCELL_SCK_PIN = 2;
const int Button_PIN = 5;
unsigned long timer ;
HX711 scale;
void setup() {
//Weight
Serial.begin(9600);
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
//For Display
Serial.begin(9600);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Address 0x3C for 128x32
display.setTextSize(1.5);
display.setTextColor(SSD1306_WHITE);
while(1){
display1();
loop();
//Weight
long val=0;
float reads=0;
float val_g=0;
float val_gm=0;
float val_lb=0;
float zero;
void loop() {
//val=scale.read();
val = 0.8 * val + 0.2 *scale.read() ; //averaging
//val_g=((val-166351)/2116.f*100);
pinMode(Button_PIN, INPUT_PULLUP);
byte buttonState = digitalRead(Button_PIN);
if (buttonState == 0 && val_g>0|| val_g<0){
zero=val_g;}
val_gm=val_g - zero;
val_lb= ((val_gm)*0.0022);
Serial.print("Weight in G=");
Serial.println(val_gm);
Serial.println(val);
Serial.print("Weight in Lb=");
Serial.println(val_lb);
void display1(){
val_g;
display.setCursor(10,0);
display.print("Gram:");
display.print(val_gm);
display.setCursor(10,10);
display.print("Pound:");
display.print(val_lb);
display.setCursor(6,6);
display.display();
display.clearDisplay();
