I have just started learning about Zener diodes and this is a quite a basic question I think.
In the following circuit, I'm supposed to calculate the current in the LED, the power supply has 6.5 V, so shouldn't the Zener diode act as a voltage regulator and be at 5 V, and then we can calculate the current which will be 20 mA.
But in the solution of my professor, it says that the answer will be 15 mA, I'm not sure how he got there as I only have the result. How does that work and what happens in the circuit?
