I am trying to understand the difference between resolution and sensitivity. After searching on the internet and the youtube I found more or less the below definition, but in practice I can't understand it.
If the resolution is smallest portion of the signal that can be observed and a multemeter has 1mV resolution (at his lower scale) then if I try to measure 0.9mV the display will show 0V (ideally) and if I measure 1mV it will display 1mV. If I measure 1.9mV it will show again 1mV. Why isn't the resolution the same thing as the sensitivity?
Definition:
- Resolution - the smallest portion of the signal that can be observed.
- Sensitivity - the smallest change in the signal that can be detected.
