There seems to be a confusion in the question. It is comparing two different types of diode circuits: a simple DC clipper and a more complex AC+DC clamper. Let's break them down.
Clipper circuit
Basic idea
If we connect an ideal voltage source with zero internal resistance in parallel with a non-ideal voltage source with some internal resistance, the voltage across the parallel combination will be equal to the voltage of the ideal voltage source. Let's illustrate this idea with conceptual circuit diagrams.
No clipping: In the picture below, a 1 V input voltage source Vin and a 1 kΩ resistor R in series form an imperfect voltage source. Since there is no load connected (only an "ideal" voltmeter), no current flows, there is no voltage drop across the resistor, and the output voltage is equal to the input one.
Positive clipping: Now, imagine that when the input voltage reaches the voltage (2 V) of the positive ideal source, the two sources are connected via a switch SW1 in parallel. The output voltage stops changing and is fixed at 2 V. Think of it like this: there is a "battle" between two voltage sources, and the ideal V1 always wins.
Negative clipping: Similarly, imagine that when the input voltage reaches the voltage (-2 V) of the negative ideal source, the two sources are connected via a switch SW2 in parallel. The output voltage stops changing and is fixed at -2 V (the ideal source V2 wins the "battle").
Implementation
In the practical circuit below, the switches are implemented with diodes.
Missing resistor: The trick above was that we intentionally "weakened" the input source by connecting a resistor in series with it, so that it always lost the battle with V1 and V2. However, in the OP's circuit, there is no such resistor, and this is the first mistake. As a result, a huge current flows through the parallel sources.
Incorrectly placed diode D2: The second mistake, as @Tim Williams also noticed, is the incorrect orientation of diode D2. As a result, at Vin > -2 V, D2
is always on, and D1 is never on (wrong operation).
Correctly placed diode D2 (clipper circuit 3): So, let's flip vertically D2...
... to obtain the accurate transfer function.
Clamper circuit
Despite being revered as a unique and complex design...
Diode rectifier
... this circuit is essentially a basic half-wave diode rectifier with a filter capacitor.
Real circuit: The capacitor charges during each positive half-wave...
... and we use its voltage as the output DC voltage.
Conceptual circuit: So, we can think of the capacitor as a constant voltage source.
Diode clamper
Here, the diode and capacitor are swapped.
Real circuit: We take the voltage across the diode as the output. In an ideal case, the diode is off...
... and this is actually the sum of the input AC voltage and the constant DC voltage across the capacitor.
Conceptual circuit: As above, we can think of the capacitor as a constant voltage source connected in series to the input voltage source...
... so their voltages are added.
