6
I've been trying to use an I²C bus between a MSP430G2553 launchpad and ITG-3200 gyroscope breakout. Here is the Launchpad datasheet and user guide and the ITG-3200 datasheet. The ITG-3200 uses a repeated start to read from a specific register. But not necessarily. After checking the example code on the Arduino (I checked the data flow on buses with an oscilloscope) I realised that even with a Stop-Start condition it should work. What I'm trying to do is to accomplish this on the MSP Launchpad.
I'm using two I²C examples provided from TI msp430g2xx3_uscib0_i2c_04 (single read) and msp430g2xx3_uscib0_i2c_06 (single write). I combined these two sets of code and came up with code for my ITG-3200 which uses a write operation followed by a read for reading it's registers. Here is the code:
#include <msp430.h>
int TXByteCtr = 1;
unsigned char PRxData;                     // Pointer to RX data
int Rx = 0;
unsigned char WHO_AM_I = 0x00;
void init_I2C(void);
void Transmit(void);
void Receive(void);
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1SEL |= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  P1SEL2|= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  init_I2C();
  while(1){
  //Transmit process
  Rx = 0;
  Transmit();
  while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
  //Receive process
  Rx = 1;
  Receive();
// The USCI_B0 data ISR is used to move received data from the I2C slave
// to the MSP430 memory. It is structured such that it can be used to receive
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
  if(Rx == 1){                              // Master Recieve?
  PRxData = UCB0RXBUF;                       // Get RX data
  __bic_SR_register_on_exit(CPUOFF);        // Exit LPM0
  else{                                     // Master Transmit
  if (TXByteCtr)                            // Check TX byte counter
      UCB0TXBUF = WHO_AM_I;                     // Load TX buffer
      TXByteCtr--;                            // Decrement TX byte counter
  else
      UCB0CTL1 |= UCTXSTP;                    // I2C stop condition
      IFG2 &= ~UCB0TXIFG;                     // Clear USCI_B0 TX int flag
void init_I2C(void) {
  _DINT();
  IE2 |= UCB0RXI             //Enable RX interrupt
  IE2 |= UCB0TXIE;                          // Enable TX interrupt
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x69;                         // Slave Address is 069h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
void Transmit(void){
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(CPUOFF + GIE);        // Enter LPM0 w/ interrupts
void Receive(void){
   UCB0CTL1 &= ~UCTR ;                  // Clear UCTR
    UCB0CTL1 |= UCTXSTT;                    // I2C start condition
    while (UCB0CTL1 & UCTXSTT);             // Start condition sent?
I don't really know why is this happening but SDA and SCL clocks keeps locking to 0V. I'm sure about the circuit (full with pull-up resistors) because that is working on an Arduino. Can you point out what seems to be the problem here?
Edit: It is better if i put the two examples from TI resource here aswell.
It is better if i give the two example of TI here. Here is the master RX single byte from the slave: ( msp430g2xx3_uscib0_i2c_04.c )
 /* --COPYRIGHT--,BSD_EX
     * Copyright (c) 2012, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *                       MSP430 CODE EXAMPLE DISCLAIMER
     * MSP430 code examples are self-contained low-level programs that typically
     * demonstrate a single peripheral function or device feature in a highly
     * concise manner. For this the code may rely on the device's power-on default
     * register values and settings such as the clock configuration and care must
     * be taken when combining code from several examples to avoid potential side
     * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
     * for an API functional library-approach to peripheral configuration.
     * --/COPYRIGHT--*/
    //  MSP430G2xx3 Demo - USCI_B0 I2C Master RX single bytes from MSP430 Slave
    //  Description: This demo connects two MSP430's via the I2C bus. The master
    //  reads from the slave. This is the master code. The data from the slave
    //  transmitter begins at 0 and increments with each transfer. The received
    //  data is in R5 and is checked for validity. If the received data is
    //  incorrect, the CPU is trapped and the P1.0 LED will stay on. The USCI_B0
    //  RX interrupt is used to know when new data has been received.
    //  ACLK = n/a, MCLK = SMCLK = BRCLK = default DCO = ~1.2MHz
    //               MSP430G2xx3      10k  10k     MSP430G2xx3
    //                   slave         |    |        master
    //           -|XIN  P1.7/UCB0SDA|<-|---+->|P1.7/UCB0SDA  XIN|-
    //            |                 |  |      |                 | 32kHz
    //           -|XOUT             |  |      |             XOUT|-
    //            |     P1.6/UCB0SCL|<-+----->|P1.6/UCB0SCL     |
    //            |                 |         |             P1.0|--> LED
    //  D. Dang
    //  Texas Instruments Inc.
    //  February 2011
    //   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
    #include <msp430.h>
    unsigned char RXData;
    unsigned char RXCompare;
    int main(void)
      UCB0BR1 = 0;
      UCB0I2CSA = 0x069;                        // Slave Address is 048h
      IE2 |= UCB0RXIE;                          // Enable RX interrupt
      RXCompare = 0;                            // Used to check incoming data
      while (1)
    // USCI_B0 Data ISR
      RXData = UCB0RXBUF;                       // Get RX data
And here is the Master TX single byte to the slave ( msp430g2xx3_uscib0_i2c_04.c )
 * are met:
 * --/COPYRIGHT--*/
//  MSP430G2xx3 Demo - USCI_B0 I2C Master TX single bytes to MSP430 Slave
//  transmits to the slave. This is the master code. It continuously
//  transmits 00h, 01h, ..., 0ffh and demonstrates how to implement an I2C
//  master transmitter sending a single byte using the USCI_B0 TX interrupt.
//                   slave         |    |        master
//  D. Dang
//  February 2011
#include <msp430.h>
unsigned char TXData;
unsigned char TXByteCtr;
int main(void)
  UCB0BR1 = 0;
  UCB0I2CSA = 0x69;                         // Slave Address is 048h
  TXData = 0x00;                            // Holds TX data
  while (1)
    TXByteCtr = 1;                          // Load TX byte counter
                                            // Remain in LPM0 until all data
                                            // is TX'd
    TXData++;                               // Increment data byte
// The USCIAB0TX_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
    UCB0TXBUF = TXData;                     // Load TX buffer
  else
  • \$\begingroup\$ Have you tried setting the pins to the required output/input setting? \$\endgroup\$
    – user17592
    Apr 29, 2013 at 9:11
  • \$\begingroup\$ Of course, as i told you my circuit is as it's required. 1.7 to SDA and 1.6 to SCL, two 10K pull-up resistors on them. The wierd part is that these two examples are working seperately. But my code which i combined them is not working so I'm pretty sure that the problem is code based. \$\endgroup\$ Apr 29, 2013 at 9:22
  • \$\begingroup\$ Yes, but did you configure the pins as output/input? You should do that in the code, not in the circuit. \$\endgroup\$
    – user17592
    Apr 29, 2013 at 9:25
  • \$\begingroup\$ I don't think that is required. Since these two pins are bus related, selecting them to USCI_B0 will do. P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 In TI's examples, they do exactly the same without any configuration on the pins except the selecting. \$\endgroup\$ Apr 29, 2013 at 9:29
  • \$\begingroup\$ Me neither, but for SPI it is required on some controllers and I follow the rule "better just do it, then you're sure". But feel free to omit it, and let's just hope it doesn't work out bad for you. \$\endgroup\$
    – user17592
    Apr 29, 2013 at 9:31
Here is the code that reading a single byte via I²C. Do not forget to connect 2 pull-up resistors on P1.6 and P1.7. These are the SDA and SCL lines on I2C bus.
#include <msp430g2553.h>
int TXByteCtr;
int Rx = 0;
char itgAddress = 0x69;
void Receive(void);
int main(void)
  init_I2C();
  while(1){
      //Transmit process
      Rx = 0;
      TXByteCtr = 1;
      Transmit();
      //Receive process
      Rx = 1;
      Receive();
        else
      UCB0BR1 = 0;
      UCB0I2CSA = itgAddress;                         // Slave Address is 069h
      IE2 |= UCB0RXIE + UCB0TXIE;               //Enable RX and TX interrupt
void Receive(void){
  • \$\begingroup\$ So how did this code solve the problem? Add more detail to how it answered the question. \$\endgroup\$
    – Dean
    Apr 30, 2013 at 8:48
  • \$\begingroup\$ I only added TXByteCtr = 1; in the while loop. Appearently, i was decrementing TXByteCtr to 0 in the first iteration and since it never went back to 1, the operation was holding. \$\endgroup\$ Apr 30, 2013 at 11:26
