Purpose: isolated measurement of DC voltage (about 600V). For these purposes, I found two options:
I am considering the second option. He needs to apply an external clock frequency (From 5 MHz) to the input and at its output there will be a stream of units, the density of which depends linearly on the input voltage.
At the output, they suggest using a sinc3 low-pass filter.
At the moment, I have no way to find an external sinc3 filter, but I'm not sure about using a software filter (since there is no such experience yet).
Questions:
- Is it possible to work without a sinc3 output filter if I measure direct current where there is no sinusoid? I will change the voltage value using a DC/DC converter (600-200V range). Or without a filter, do not know the actual value of the voltage? What if we sample values and get the average.
- CLKIN will be at 5MHz, what frequency will the output data be? I don't plan to check the voltage value so often. The datasheet has the 'fdata' value, but it is associated with the sinc3 filter.
P.s. As a microcontroller I use STM32F3
Thank you!
