An op-amp cannot output a potential (voltage) greater than its own positive supply potential. That's +5V in your case. No op-amp can output a potential less than its own negative supply potential, that's 0V here. Since your op-amp's negative supply is 0V, you will never obtain an output under 0V.
Worse still, no op-amps that I know of can output potentials all the way to either supply potential. The 741 is the worst offender. Referring to the datasheet (page 5, "Output voltage swing") you will find that this device can't get its output closer than 1V to either supply rail. It might even be worse than this; in the worst case, if you are unlucky enough to have bought the worst 741 in existence, you might not even get within 3V!
Typically, for a 741 with 0V and +5V supply potentials, the output will never be outside the range +1V to +4V. The 741 is a terrible choice for any application, and I believe your +1.37V output is a symptom of this constraint. For this reason, among others, the 741 is not recommended for operation at 5V.
Your own design is an inverting amplifier with gain \$-\frac{10k\Omega}{10k\Omega}=-1\$. With an input of +5V, you seem to expect an output of -5V, which is impossible without a negative supply beyond -5V. If you want a negative output, you must provide a negative supply to the op-amp. To produce -5V out, the 741 will require a negative supply of at most -6V, probably even lower (more negative).
All op-amps also require that input potentials fall within a certain range. The 741 will not tolerate inputs that get closer than 2V from either supply rail, as can bee seen on page 5, under "Input voltage range". Therefore, with supplies of 0V and +5V, you may not apply anything outside the range +2V to +3V to either of the 741 inputs! If you do, then you can expect the op-amp to behave badly, with unpredictable outputs. Again, the 741 is clearly not suited for such a low supply voltage.
There are much better op-amps than the 741. Consider, for example, the TLC2272 or AD822 which will work well with supplies of 0V and +5V, can produce an output to within tens of millivolts of those supplies, and can tolerate input potentials all the way down to the negative supply (0V in your case).
There are not many op-amps that will work with inputs all the way up to the positive supply, since this isn't a common requirement.
Your diagram may be fine for people at Lego or Fisher-Price, but it isn't appropriate for a second-year engineering student. There are many free tools that permit you to create professional schematics, one of which is CircuitLab, used by this very site. Others are LTSpice and Kicad (which uses ngspice). All of them provide simulation features, and all are free. I recommend that you try CircuitLab for a very easy and intuitive interface and experience. Here's your schematic produced using CircuitLab:
It's not the best simulator in the world; it has very simplistic models (which is why you see 24mV output, instead of one-point-something), but it's designed for use in a web browser, and for simplicity. It's an excellent tool to get something done quickly, and for a ball-park idea of behaviour. And it makes really pretty easy-to-read schematics.
With a small change, a sufficiently negative supply for the op-amp, we can immediately see the desired result:
