For designing a low side non-sync buck regulator I am looking for MOSFET(s) that can provide low overall power loss. Conditions would be 60V to 48V, 10A, 600 kHz (worst case), 1 Ohm source and 0.35 Ohm sink gate driver. Schematic would be as shown below, although without a LED load.
[Reference image from https://shadyelectronics.com/low-side-buck-step-down-converter/]
For this I was using the Cross reference comparison tool by EPC that provides the various power loss for a MOSFET for switching conditions specified. If we take a potential MOSFET such as FDD86110, we see that the diode reverse recovery loss is much higher than other losses. This is validated by calculation of loss by P=Vin×Qrr×Fsw
My questions would be
- If this loss is such a big part of power loss at higher voltage, why don't most manufacturers or sellers have this as a criteria to sort or filter MOSFETS? And what is a good way to find MOSFETs with low Qrr along with other filter criteria.
- Schottky diode in parallel to the MOSFET would reduce power loss? If yes, how to calculate the power loss with this?
- Is there any other way to reduce this power loss?
