I am trying to write memory elements using for loop. The for loop runs, and I get the value of k changing 10 times. But I am not getting write and select values changing; they remain constant. As they are in while loop so wouldn't they change?
initial
begin
for(k=0; k<10; k=k+1)
 begin
  address=k;
  data_in=(k+k);
  write=1; select=1;
  #2 write=0; select=0;
 end
end
You have zero-time glitches on the write and select signals, but you can't see them in waveforms. You need to add another delay inside the loop; the single #2 delay that you have is insufficient.
Here is a runnable example, where I added another #2 at the end of the for loop:
module tb;
reg write, select;
integer k, address, data_in;
initial
begin
    for (k=0; k<10; k=k+1) begin
        address=k;
        data_in=(k+k);
        write=1;
        select=1;
        #2 write=0;
        select=0;
        #2;
    end
end
endmodule
The waves show write and select changing.
The waveforms were generated from the Synopsys Verdi tool.
  • \$\begingroup\$ which simulator are you using? \$\endgroup\$
    – Zerox
    Aug 4, 2023 at 18:11
  • \$\begingroup\$ @Zerox: I used a couple simulators to check this: Cadence and Synopsys. Why do you ask? Do you get a different result? This should work on all simulators. \$\endgroup\$
    – toolic
    Aug 4, 2023 at 18:13
  • \$\begingroup\$ Than you for reply....Ut works for me....As modelsim and vivado simulator only gives green waveform by default.It is colourfull so looks amazing \$\endgroup\$
    – Zerox
    Aug 4, 2023 at 18:19
  • \$\begingroup\$ @Zerox: You're welcome. I updated my Answer with the tool information. What should I do when someone answers my question? \$\endgroup\$
    – toolic
    Aug 4, 2023 at 18:21
The write and select are changing, but you are continuously overwriting them. Each time your For Loop iterates, it sets write = 1 and then sets write = 0, this repeats itself 10 times so after the loop has ended both your write and select = 0
