I've learned USART of PIC16F883, and I want to learn UART of dsPIC33FJ64MC802.(Actually I need to learn dsPIC, but I learned PIC16F883 first since I thought it's easier to learn.)
Here's my circuit diagram of PIC16F883 in Proteus simulator(I can send messages to virtual COM port):
And here's the code:
void main() {
     char ch;
     UART1_Init(19200);
     Delay_ms(100);
     while(1)
             if(UART1_Tx_Idle())
                 UART1_Write_Text("OK2\r\n");
             Delay_ms(500);
I have found some resources teaching dsPIC UART, but I can hardly read the sample code. And I don't know how to what's the circuit of the sample code and how to learn. Can anyone provide some help? How can I learn dsPIC UART based on the what I've learned from PIC?
1.UART Example for DSPIC33 (DSPIC33FJ128GP802)
2.Setting up RS232 transmission on a dsPIC
3.dsPIC33F UART transmission problem
4.Thread: [dspic33] UART - Transmits ok, but receives garbage
EDIT:
An easy way to run dsPIC UART is using mikroC for dsPIC, it's very user friendly. It provides sample code and the code is easy to understand.
You have unfortunately not learned much from your previous UART experience if that is all the code you have. Here it seems like you have used a couple of libraries (i.e header files) which has implemented all the "tricky" stuff for you.
I would suggest that you take a look in your code and open up the UART1_Init() function. This is most likely included as uart.c and uart.h, where the .c-file is the actual implementation.
Here you will find how UART actually works, and when you have learned this you can move on to other controllers. As a matter of fact, look in to all of your uart-functions and study them, finding out what every line means. This is the most common way to learn code: To study code, understanding it and write your own.
| improve this answer | |
I suggest looking at the Microchip XC16 documentation that comes in the \docs folder of the installation, specifically 16-Bit_Language_Tools_Libraries_51456.pdf (for XC16 version 1.11). This has lots of UART examples and explains how to use the XC16 library functions to control the UART.
I also suggest Microchip's Embedded Code Source site, as there are lots of samples available there.
If you really want to learn the UART, take a look at my canned UART code for PIC and dsPIC. This should be included in the PIC Development Tools release at http://www.embedinc.com/pic/dload.htm. Look for files with "uart" in their names in the SOURCE > PIC and SOURCE > DSPIC directories within the software installation directory.
For example, source/pic/uart.ins.aspic implements a highly configurable low level interface to most 8 bit PIC UARTs. You can specify whether it uses interrupts or polling, input and output FIFOs, etc. The dsPIC counterpart will be source/dspic/uart.ins.aspic. One nice thing about the dsPIC architecture is that each interrupt is individually vectored, so it is possible write a self-contained UART module that handles interrupts and all in the same file.
