I have a hard time understanding BJTs in saturation. I was answering this problem but I can’t get the answer. I did was like this
The givens were only that so I’m really don’t get the answer
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have a hard time understanding BJTs in saturation. I was answering this problem but I can’t get the answer. I did was like this
I very much dislike the question. Given the answer you show as correct, there is an implication that both the active mode and saturation mode \$\beta=100\$. Even as \$V_{_{\text{CE}\left(\text{SAT}\right)}}=200\:\text{mV}\$. This is never the case. Not ever.
The only logical remedy is to believe that there is an active mode \$\beta\$ that is higher than 100 and that the stated \$\beta\$ is for the case where \$V_{_{\text{CE}\left(\text{SAT}\right)}}=200\:\text{mV}\$. But I don't believe it. Just doesn't happen that way.
So I don't like it.
But granting it, then:
\$V_{_\text{BE}}=700\:\text{mV}\$
Saturation condition is \$\left(\frac{\beta+1}{\beta}\cdot 680\:\Omega+2.7\:\text{k}\Omega\right)\cdot I_{_\text{C}}=12\:\text{V}-V_{_{\text{CE}\left(\text{SAT}\right)}}\$
Solve to find \$I_{_\text{C}}\approx 3.484\:\text{mA}\$
\$V_{_\text{E}}=\frac{\beta+1}{\beta}\cdot I_{_\text{C}}\cdot 680\:\Omega\approx 2.393\:\text{V}\$
\$V_{_\text{B}}=V_{_\text{BE}}+V_{_\text{E}}\approx 3.093\:\text{V}\$
\$R_{_\text{B}}\le\frac{12\:\text{V}-V_{_\text{B}}}{\frac{I_{_\text{C}}}{\beta}}\$ or \$R_{_\text{B}}\le\left(\frac{8.907\:\text{V}}{34.84\:\mu\text{A}}\approx 255.6544\:\text{k}\Omega \right)\$
Rounded to 5 places this matches the given answer.
Ie=Ic+Ib=Ic+Ic/b=Ic*(b+1)/b
Aug 6 at 12:59
You failed to account for the voltage across the 680Ω resistor, making your assertion \$I_C=\frac{12-V_{CE}}{2700}\$ incorrect. By KVL, the corrected voltage \$V_{RC}\$ across the resistor \$R_C=2700\Omega\$ will be:
$$ \begin{aligned} V_{RC} &= 12-V_{CE(SAT)} - V_{RE} \\ \\ I_CR_C &= 12 - 0.2 - I_ER_E \\ \\ 2700I_C &= 11.8 - 680I_E \\ \\ \end{aligned} $$
KCL:
$$ \begin{aligned} I_E &= I_C + I_B \\ \\ &= I_C + \frac{I_C}{\beta} \\ \\ &= I_C(1+\frac{1}{\beta}) \\ \\ &= 1.01I_C \end{aligned} $$
Plug \$I_E\$ into the KVL equation:
$$ \begin{aligned} 2700I_C &= 11.8 - 680\times1.01I_C \\ \\ 2700I_C &= 11.8 - 686.8I_C \\ \\ 3386.8I_C &= 11.8 \\ \\ I_C &= 3.4841mA \end{aligned} $$
I cringe to quote so many significant figures, but since your "official answer" has that many, I'll just grin and bear it.
Now you have \$I_C\$, you can work out \$V_{RE}\$ and \$I_B\$, and derive a corresponding value for \$R_B\$. Again you neglected the voltage across the emitter resistor in your calculation for the voltage across the base resistor. The correct KVL equation is:
$$ \begin{aligned} V_{RB} &= 12-V_{BE} - V_{RE} \\ \\ I_BR_B &= 12 - 0.7 - 680I_E \\ \\ \frac{I_C}{\beta}R_B &= 11.3 - 680(1+\frac{1}{\beta})I_C \\ \\ \end{aligned} $$
I'll leave finding \$R_B\$ up to you.
It appears (after simulation), that the assumptions surrounding this question are: -
So, if this is modelled in a simulation tool (micro-cap) you find this: -
And, by manipulation of R3, I get an answer of exactly 200 mV between collector and emitter.
R3 is 255.64915 kΩ.
The correct answer is apparently 255.65 kΩ.
Nowhere in your question did you state what method should be used.
However, should you decide retrospectively that this problem has to be solved using math then, I hope you can see that the simulation above indicates where your problem currently is. Here's an example that assumes R2 is zero ohms: -
Now, the new value for R3 is 258.55933 kΩ but, because your handwriting is so bad I can't confirm that this is what you did although I suspect it is.
