I'am using the STOP2 mode in stm32wb55 microcontroller. I followed the stm example code and got the desired behavior with a power consumption of 10 µA. However for my application I need to leave one GPIO pin enabled as an EXTI to wake up the MCU. When I did that I measured a current consumption of 100 µA which seems too high, is this consumption normal for 1 EXTI pin? If not is there any mistake in my code? Thank you.
`void stop2mode(){
HAL_UART_DeInit(&huart1);
HAL_UART_DeInit(&hlpuart1);
HAL_ADC_DeInit(&hadc1);
HAL_I2C_DeInit(&hi2c1);
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.Pin = GPIO_PIN_All;
GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
GPIO_InitStructure.Pull = GPIO_NOPULL;
//  HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOE, &GPIO_InitStructure);
//  __HAL_RCC_GPIOA_CLK_DISABLE();
__HAL_RCC_GPIOB_CLK_DISABLE();
__HAL_RCC_GPIOC_CLK_DISABLE();
__HAL_RCC_GPIOD_CLK_DISABLE();
__HAL_RCC_GPIOH_CLK_DISABLE();
__HAL_RCC_GPIOE_CLK_DISABLE();
GPIO_InitStructure.Pin = GPIO_PIN_10;
GPIO_InitStructure.Mode = GPIO_MODE_IT_RISING;
GPIO_InitStructure.Pull = GPIO_PULLDOWN;
GPIO_InitStructure.Speed = GPIO_SPEED_FREQ_LOW;
/** ### Start the timeout function in interrupt mode ################# */
HAL_LPTIM_TimeOut_Start_IT(&hlptim1, 0xFFFF, period);
/* Enter STOP 2 mode */
HAL_SuspendTick();
HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);
HAL_ResumeTick();
  • \$\begingroup\$ 10uA is the advertised lowest current draw, 100uA seems pretty low when you have a pin enabled. What makes you think it's too high? \$\endgroup\$
    – Puffafish
    Aug 9, 2023 at 14:43
  • \$\begingroup\$ I have no idea how much does a GPIO port consume. I was using the interrupt from the low power timer to wake up the MCU and it was 17µA so 100µA seemed like a lot. I have to to reduce power to the minimum in sleep mode because the device will be mostly sleeping. \$\endgroup\$ Aug 9, 2023 at 14:49
  • \$\begingroup\$ without the schematics It is not possible to say. One pull or pull up can do this. \$\endgroup\$ Aug 9, 2023 at 17:35
I can't say without delving into the documentation just what will become enabled in an STM32 Cortex when you enable one GPIO, but at the very least, a clock on the GPIO peripheral gets turned on. 100 \$\mu A\$ doesn't seem unreasonable. You could try lowering the clock rate on that bus to see if you can nudge that number down. You should also check to see if you configured a pull-up or pull-down, and disable that if your design allows.
  • \$\begingroup\$ So i should check the clock tree in the datatsheet, and lower the speed of the APB or AHB bus that powers that GPIO ? \$\endgroup\$ Aug 9, 2023 at 15:08
  • \$\begingroup\$ @Faiz-983654 that's certainly one approach. I don't know how much quiescent current that will save, but even a little will start showing where the current is going. Also, I'd have to do some reading to figure out if "GPIO_InitStructure.Speed" does this or not. I also notice that you do, indeed, have a pulldown on that bit. Try disabling that. \$\endgroup\$ Aug 9, 2023 at 15:18
  • \$\begingroup\$ Also, why are you initializing 5 GPIO (B through E) to allow for one wake up bit? If those GPIO aren't all on the same bus, you might be turning on more than one bus clock. \$\endgroup\$ Aug 9, 2023 at 15:21
  • \$\begingroup\$ So i disabled the pull-down resistor but it did'nt change much. And the intilise function initilises the other GPIO ports as analog which consumes the least and than disables their clocks. I got that part from the ST example codes. \$\endgroup\$ Aug 10, 2023 at 7:21
Internal resistance of the pin is between 30 to 50k. If supplied from 3.3V it will consume from 110uA to 66uA.
You have your power consumption :)
  • \$\begingroup\$ The pin is configured as Pull down so it is not connected to a 3.3v so theoretically it shouldn't consume anything. I tried configuring the pin as just a GPIO input with pulldown resistor and it doesn't consume any current. The excess consumption occurs when i configure it as an EXTI so i think it has something to do with the interupt handler circuit. \$\endgroup\$ Aug 10, 2023 at 8:11
