I am having trouble with getting the ESP32-C3-DevKit-M1 to wake up from deep sleep. I have reached out on other forums and have been told that the code works for them, but unfortunately, it does not seem to work for me.
#include "esp_sleep.h"
#include "driver/gpio.h"
#define INTERRUPT_PIN 3
RTC_DATA_ATTR int bootCount = 0;
void setup() {
   Serial.begin(115200);
   delay(1000);
   ++bootCount;
   Serial.println("Boot number: " + String(bootCount));
   print_wakeup_reason();
   Serial.println("Starting");
   delay(2000);
   for(int i=3; i!=0; i--){
   Serial.println(i);
   delay(1000);
Serial.println("Going to sleep now");
pinMode(INTERRUPT_PIN, INPUT);
esp_deep_sleep_enable_gpio_wakeup(1 << INTERRUPT_PIN, ESP_GPIO_WAKEUP_GPIO_HIGH);
gpio_set_direction((gpio_num_t)INTERRUPT_PIN, GPIO_MODE_INPUT);  // <<<=== Add this line
esp_deep_sleep_start();
Serial.println("This will never be printed");
void loop() { }
   void print_wakeup_reason() {
   esp_sleep_wakeup_cause_t wakeup_reason;
   wakeup_reason = esp_sleep_get_wakeup_cause();
   switch (wakeup_reason) {
       case ESP_SLEEP_WAKEUP_EXT0:
          Serial.println("Wakeup caused by external signal using RTC_IO");
          break;
       case ESP_SLEEP_WAKEUP_EXT1:
          Serial.println("Wakeup caused by external signal using RTC_CNTL");
          break;
       case ESP_SLEEP_WAKEUP_TIMER:
          Serial.println("Wakeup caused by timer");
          break;
       case ESP_SLEEP_WAKEUP_TOUCHPAD:
          Serial.println("Wakeup caused by touchpad");
          break;
       case ESP_SLEEP_WAKEUP_ULP:
          Serial.println("Wakeup caused by ULP program");
          break;
       default:
          Serial.printf("Wakeup was not caused by deep sleep: %d\n", wakeup_reason);
          break;
I do not think the problem could lie in the code if multiple others have ran it and said it had worked for them, but I provided the code just in case. I will also provide the basic breadboard setup below:
Breadboard for ESP32-C3 in Deep Sleep
The resistor value acting as a pull down is 10kohms. The output and serial monitor print the following:
Serial Monitor
Output
Any help in trying to fix this issue with waking up the esp32-c3 is really appreciated, thanks!
  • \$\begingroup\$ "Other forums" - this is not a forum. It is a Q&A. \$\endgroup\$
    – JYelton
    Commented Aug 10, 2023 at 15:35
    \$\begingroup\$ please do not post pictures of text here ... post the text instead ... some people cannot view pictures \$\endgroup\$
    – jsotola
    Commented Aug 10, 2023 at 16:55
For ESP32-C3, ESP_SLEEP_WAKEUP_EXT0 and ESP_SLEEP_WAKEUP_EXT1 are not available, and wakeup by GPIO return a wakeup_reason of 0x05(ESP_SLEEP_WAKEUP_GPIO). So you need to add it in your switch..case block.
    case ESP_SLEEP_WAKEUP_GPIO:    // 05 - this is used by ESP32-C3
      Serial.println("Wakeup by GPIO");
      break;
    // other cases...
BTW, if you connect the switch between the GPIO pin and GND, you can set the pinMode as INPUT_PULLUP, this will save you the need for external resistor, but in this case you will need to use ESP_GPIO_WAKEUP_GPIO_LOW as wakeup trigger. This is just my personal preference of using the internal pull-up resistor instead of adding external component.
  pinMode(INTERRUPT_PIN, INPUT_PULLUP);
  esp_deep_sleep_enable_gpio_wakeup(1 << INTERRUPT_PIN, ESP_GPIO_WAKEUP_GPIO_LOW);
Reference:
Sleep Modes (ESP32-C3)
  • \$\begingroup\$ Great! Thanks so much. I'll explore on that idea of using the input_pullup as well. I appreciate the help! \$\endgroup\$
    – Abhi
    Commented Aug 11, 2023 at 14:51
