I added a 3D body to the PCB document from outside. (i.e. these 3D bodies were not included in the PCB documentation as components from the schematic). However, when I try to delete it, it does not select and delete, I can only change the location of the body. Does anyone know the solution? I tried deleting it with version 2021; version 2023 still has the same problem. Does anyone have this problem?
In the selection section, only select "components" is marked, the problem is solved.
