This is part of a 4 channel WiFi switch - most probably a resistive or capacitive touch controller. However, I am unable to find any reference online using marking from the chip (145AZ01 A2E1A53 C). Any help will be appreciated.
This could be an R7FA2E1A53CFJ#AA0 ARM microcontroller. I just searched for the the second line of your marking.
https://www.mouser.de/datasheet/2/698/r01ds0386ej0130_ra2e1-2930932.pdf Pinout on page 19.
You can test this by measuring the Resistance between Pin 1 and 7 when the device is turned off. If it's not near zero, you can rule this family of microcontrollers out.
    \$\begingroup\$ It's the right controller, lcsc.com has a picture and it matches. \$\endgroup\$
    – nanash1
    Aug 14, 2023 at 6:30
  • \$\begingroup\$ Hans, Nanash - thank you both for helping out, much appreciated. \$\endgroup\$ Aug 14, 2023 at 7:14
