Can somebody please help to identify what kind of IC this is? It is from a PetNet Smartfeeder v1. It has the top mark "UTREW". The company is no longer around.
Chip in question
Zoomed out area of the chip in question
    \$\begingroup\$ Identification of components is greatly aided by context: What device is it in? What are the surrounding components? Please see electronics.stackexchange.com/q/627046/2028 for a good example of how to ask a component identification question. \$\endgroup\$
    – JYelton
    Aug 14, 2023 at 18:53
  • \$\begingroup\$ I'm not coming up with matches for the top mark. I did find full images of the mainboard in the product at iFixIt, hoping for some detail on the components; no such luck. At first I thought it was an 8-pin SOIC, but based on the images, it may be an 8-pin VSSOP instead. \$\endgroup\$
    – JYelton
    Aug 14, 2023 at 21:59
  • \$\begingroup\$ You may have better luck asking a community that has access to working units to measure and characterize the IC. Also there appears to be a chance you could obtain a replacement board from people who are frustrated by the circumstances that appear to surround this device and are just throwing it away. \$\endgroup\$
    – JYelton
    Aug 14, 2023 at 22:18
  • \$\begingroup\$ Could you add measurements of the package? Especially the pitch. I tried to use the available pictures and the best I could come up with is a 0.5 mm pitch. The only 8 pin package I could find with that pitch is SC70-8, but the few devices that use this package, like the LT3491, have different markings. \$\endgroup\$
    – nanash1
    Aug 15, 2023 at 7:46
The markings match with a Skyworks (formerly Analogic) AAT3681AIJS-4.2-T1 Battery Charger. The pinout is also plausible since pin 6-8 are ground and they are connected in the picture.
I could only find a picture of the AAT3681AIJS-4.2-4-T1, but it shows the marking style matches as well.
(source: taobao.com)
