Quick background on myself: I work as an engineering tech at a company that manufactures instrument transformers. I assist our technical director with designing transformers, however I do not have an electrical engineering degree and am sort of learning on the job (kind of like an apprenticeship situation).
That being said, we had a customer for whom we were developing a Rogowski coil which was to be assembled in a plastic case and encapsulated. Ultimately they opted for a PCB Rogowski Coil due to size constraints. I found it interesting that this was possible, because I was under the assumption that a turn in a coil had to be a loop of wire around a core (in this case an air core) and i thought this had to do with the core containing an alternating flux which, with the right-hand rule, induces a voltage in the windings that are wound perpendicular to the core. However, in the image below the windings seem to be laid down on top of the PCB ring (air core) rather than as loops of wire.
Image source: IEEE PSRC Special Report, Practical Aspects of Rogowski Coil Applications to Relaying, September 2010
I'm essentially curious as to what really constitutes a turn in a coil geometrically? Is it any conductor on a core that is normal to the ID and OD (and therefore perpendicular to the flux) whether its a loop around the core or if it's zig-zagged like as shown in the picture above?
